LabVIEW MathScript RT Module
if/else statement in MathScript Node
I want to write if/else statement in MathScript Node.
if (yes == yes)
a = 0;
else (no = no)
b = 1;
"Yes" and "No" --> Type String
"a" and "b" --> Type Double
(11,096 Views)
Accepted by topic author johndoe8815
Hi johndoe,
Thanks for contacting National Instruments.
I would like to point out a number of articles which you may find helpful for setting up an if-else statement in a MathScript Node.  The first is a white paper tutorial, the second part of which explains how to use MathScript Nodes in LabVIEW. The second is an article describing the required syntax for writing functions and scripts within the MathScript Node, including instructions for the use of If-Else Statements. [links have been removed; MathScript is no longer supported in LabVIEW.]
I hope these help. Please let me know if you require any further assistance.
Kind regards,
James
(11,077 Views)
