LabVIEW Interface for Arduino Discussions
sending variable from labview to the arduino
Hello all,
I'm trying to send some variables back from the labview to the arduino with no success till now.
I tryed to add new case for the sketch of the arduino interface and send value via the send receive Vi.
no responding.
I will be very happy if anyone can help.
Sketch add in the cases:
       case 0x1E: // test case
       pinMode(12,OUTPUT);
       digitalWrite(12,HIGH);  // indicate if execute
       Setpoint[command[1]]==700; // just try to give new value
       Serial.write( byte(0) );
        break;
       case 0x1F: // test case
         pinMode(0,OUTPUT);
         digitalWrite(12,LOW); // indicate if execute
         Setpoint[command[1]]==200;  // just try to give new value
          break;
(4,688 Views)
Hey hraanan,
Looking at the write digital pin as an example:
case 0x03:    // Write Digital Pin
      digitalWrite(command[2], command[3]);   //Write out on the pin specified at command[2] the value at command[3]
      Serial.write('0');  //Write a confirmation back to LabVIEW
      break;
In this example you would set the Send/Receive in LabVIEW to expect 1 byte.  You need to pass Send/Receive the command byte first followed by as many data bytes as you want.
In the code you provided I am not sure what you are trying to do with this line: Setpoint[command[1]]==200;  // just try to give new value
To use the value you send to the Arduino board I would expect you to want something like Setpoint =command[2];
Post back if you have any questions.
Kevin Fort
Principal Software Engineer
NI
(3,428 Views)
hraanan,
Were you able to accomplish this task? If so, would you post the solution?
I am trying to do something similar.
CLD Certified 2014
(3,428 Views)
