LabVIEW Interface for Arduino Discussions
lifa problem
Hello everyone!
I opened the LIFA_Base.INO file in the arduino.exe and whem i tried to upload that program it shows an error  that serial port has not been selected correctly even though i have installed the drivers for my arduino board mega2560.
this problem was not there initially and i also did the program of led blink but now it is showing the error of the serial port my pc is unable to recgonize that board.
(4,061 Views)
Do you see the Arduino in Windows device manager?  If so what com port does it show up as?  You should always check the COM Port and board type in the Arduino IDE before deploying.
Keep in mind the COM Port assosicated with the Arduino may change when you attach / detach the board.  This is because windows tries to be helpful and doesn't always release the COM port number it assigns to the Arduino.
-Sam K
LIFA Developer
(3,540 Views)
thank you for the reply.
the problem is solved.
(3,540 Views)
