LabVIEW Interface for Arduino Discussions
compilation error while uploading LIFA_Base to arduino board
while compiling the file:
C:\Program Files\National Instruments\LabVIEW 201x\vi.lib\LabVIEW Interface for Arduino\Firmware\LIFA_Base
sostware used:
Arduino: 1.5.8 (Windows 8), Board: "Arduino Mega or Mega 2560, ATmega2560 (Mega 2560)"
compilation error:
C:\Program Files (x86)\Arduino\libraries\RobotIRremote\src\IRremoteTools.cpp:5:16: error: 'TKD2' was not declared in this scope
int RECV_PIN = TKD2; // the pin the IR receiver is connected to
Error compiling.
  This report would have more information with
  "Show verbose output during compilation"
  enabled in File > Preferences.
(7,951 Views)
Accepted by skmr168
This happens because LIFA is very old and no longer supported.  If possible, you should upgrade to LINX.
(7,242 Views)
Here you have the solution to your problem.
https://decibel.ni.com/content/message/125048#125048
If you solve the issue, please check the reply like a right answer.
Regards
(7,242 Views)
then we have to always use LINX instead of ARDUINO while making project ??
i did it like this----
but now will i use NINX for initialization, input/output etc. ??
(7,242 Views)
LINX is a complete replacement for LIFA.  Check it out, look at the examples, etc.  You will see.
(7,242 Views)
yes,by doing that it worked
but don't you think that removing those files will not affect my other arduino programs??
plz help in this regard....
(7,242 Views)
