LabVIEW Interface for Arduino Discussions
arduino pid library compatible with labview's pid.vi??...any idea??
i am working on a quadcopter project...
i wanna tune the pid controller using system identification toolkit... like in this tutorial..
http://techteach.no/presentations/nidays05/index.htm#analysis
creating the log-file is quite easy...and next deducing z-domain TF is also easy...and next designing the controller, ie.pid values ,is guaranteed ...
the problem is to find an arduino pid library compatible with the labview's pid.vi...any idea???
i first considered converting the pid.vi 's block diagram to c code..i figured out it is almost impossible..as i don't have enough experience with labview...then i went for the c-generator toolkit...it looks like even worse...so i am apprecited to any help...
(6,100 Views)
notice i am not using labview's LIFA toolkit..it's all arduino code..
if there is one compatible with simulink's pid library..maybe even better..as the autotuning utility in simulink is more intuitive
(3,552 Views)
If you are looking for PID code for Arduino, I recommend that you search for it in Arduino-based websites (or use Google) since PID is not a LabVIEW-specific control algortithm.
(3,552 Views)
yes..i 've got plenty of arduino pid libraries..like here in github
https://github.com/search?q=arduino+pid+library&type=Repositories&ref=searchresults
the point is, as said before, i wanna use the system identification toolkit like this...
the problem is that pid library in labview is different from the ones listed in the above github link...
if i use the labview's, or simulink's, autotuner  ...it won't work
so i tried to compare labview's pid library with the ones i have...but i don't have enough experience with labview ... i did another trials like c-generator toolkit ..it didn't work..that's it...
(3,552 Views)
