LabVIEW Interface for Arduino Documents
LabVIEW Interface for Arduino Packets
Below is a table containing information about how the LIFA packets are built.  This is a work in progress as of 6/27 and should be completed soon.  Please let me know if you have any questions about this (most people won't need to worry about how this works under the hood.  This is for the benefit of advanced users).
FunctionDescriptionHeaderCommandARG0ARG1ARG2ARG3ARG4ARG5ARG6ARG7ARG8ARG9ARG10ARG11ARG12ChecksumReturn
SyncUsed to synchronize LabVIEW and the Arduino (Required in wireless mode).0xFF0x00xxxxxxxxxxxxxChecksum"sync"
FlushFlush serial buffer on Arduino.0xFF0x01xxxxxxxxxxxxxChecksumNone
Set Pin ModeSets digital pin mode as input or output.0xFF0x02PIN
MODE:
0 - INPUT
1 - OUTPUT
xxxxxxxxxxxChecksum0x00
Write Digital PinWrites a value to digital I/O pin.0xFF
0x03
PIN
Value:
0 - LOW
1 - HIGH
xxxxxxxxxxxChecksum
0x00
Write Digital Port
Writes a value to digital I/O pins 0 - 13.  Each bit represents a pin value from MSB (Pin 13) to LSB (Pin 0)0xFF0x04PIN 13- 8PIN 7 - 0xxxxxxxxxxxChecksum0x00
ToneGenerates a square wave of the specified frequency (and 50% duty cycle) on the specified pin.0xFF0x05
Checksum0x00
Read Digital PinReads the value of a digital input pin.0xFF0x06
Checksum
Read Digital PortReads the value of digital input pins 0 - 13.0xFF0x07
Checksum
Read Analog PinReads the analog voltage of the specified analog input pin.0xFF0x08
Checksum
Read Analog PortReads the analog voltage of analog input pins 0-5.0xFF0x09
Checksum
Write PWM PinWrites a PWM signal with the specified duty cycle on the specified PWM pin.0xFF0x0A
Checksum
Write PWM PortWrites a PWM signal to three PWM pins.0xFF0x0B
Checksum
Config Seven SegConfigures pins to use with seven segment display.0xFF0x0C
Checksum
Write Seven SegWrites a character to the seven segment display.0xFF0x0D
Checksum
I2C InitInitialize I2C and join the bust as master.In0xFF0x0E
Checksum
I2C SendSend I2C data.0xFF0x0F
Checksum
I2C ReadRead I2C data.0xFF0x10
Checksum
SPI InitInitialize the SPI bus.0xFF0x11
Checksum
SPI Set Bit OrderSet data transmission bit order.0xFF0x12
Checksum
SPI Set Clock DividerSet SPI clock divider.0xFF0x13
Checksum
SPI Set Data ModeSet SPI data mode0xFF0x14
Checksum
SPI Send / Receive
Send and Receivce SPI data0xFF0x15
Checksum
SPI Close
Close SPI Bus0xFF0x16
Checksum
Set Num ServosSet the number of servos to use in your application and dynamically allocate memory for them.0xFF0x17
Checksum
Config ServoConfigure servo by setting which pin to use and angle range limits.0xFF0x18
Checksum
Servo Write AngleWrite a target angle for the specified servo.0xFF0x19
Checksum
Servo Read AngleRead the last target angle sent to the servo.0xFF0x1A
Checksum
Servo Write uS PulseWrite a uS pulse for the specified servo.0xFF0x1B
Checksum
Servo Read uS PulseRead the last uS pulse width sent to the specified servo.0xFF0x1C
Checksum
Servo DetachDetach the specified servo so that the DIO pin is free to be used for DIO.0xFF0x1D
Checksum
Comments
A.Fiore
on
Hello, i think this packets are great and could solve some problems i found trying to connect LabVIEW and Arduino for a project.
I started to use LIFA and i found a mistake in the definition of the number of "analog pin" for the Arduino Mega 2560: there are 16 analog pin and not only 8. I had to modify the "Analog Pin.ctl" and "Check for pin out of range.vi" to make it work properly.
I got also a question: i have to read a sensor with a frequency output, i've already made an attempt using only arduino reading a digital pin and using the function "pulseIN". how can i do this using LabVIEW? is it possible to use on of the packet in the table?
Thank you
Andrea
N8DMT
on
Is an updated version of the LIFA Packets table available?  Looking for additional info on the stepper motor commands (30 and up).
Gerry99
on
Could you added command for reading intterupt pin in arduino ?? So labview could read and count for RPM measurement..
it's still common problems..
Gerry
Contributors
