0. What is the LabVIEW Interface for Arduino?
1. What operating systems does the LabVIEW Interface for Arduino support?
2. Which version of LabVIEW do I need to use the LabVIEW Interface for Arduino?
3. What hardware is required to use the LabVIEW Interface for Arduino?
4. How do I install the LabVIEW Interface for Arduino?
5. Where can I get support for the LabVIEW Interface for Arduino?
6. How can I get started using the LabVIEW Interface for Arduino?
7. Can I deploy LabVIEW Code to my Arduino?
8. Do I have to be tetherd to a computer to use the LabVIEW Interface for Arduino?
9. Can I add my own sensors to the LabVIEW Interface for Arduino?
10. How does the LabVIEW Interface for Arduino work?
10. How does the LabVIEW Interface for Arduino (LIFA) work?
You mention in the FAQ that the LIFA works in labview 2009, however the LIFA package seems to only be compatible with labview 2010.
Michael,
Thanks for catching this. It will be fixed in the next build.
-Sam
Hello Sam,
Great work on the LIFA.. have you make it compatible with Labview 2009?
Grape,
We are still working to track down why the package is only compatible with 2010. It should be build for 2009 or later but it seems to like 2010 best. I'll post an update as soon as we get this worked out.
-Sam
LIFA Developer
Thanks Sam...
All,
I just sent out a new version of LIFA to be added to VIPM. Build 1.3.0.26 now fully supports LabVIEW 2009 or later and also includes servo VIs. I hope that it will go live today, but may take until Monday 6/6 to work its way into the repository. Grab the new version, update the firmware on your arduino and you should be good to go. As always keep posting feedback so we can add features and fix any bugs that arise.
-Sam
LIFA Developer
The new LIFA version that supports LV2009 is up and it works! I ran the Analog Read Pin Example.vi with no problems whatsoever. I am looking forward to working with this interface further.
Thanks Sam!
-Nick
Nick,
No problem. Make sure you post any feedback you have or any cool projects you work on.
-Sam
LIFA Developer
Can the Arduino accept 0-10V.I mean, will the Arduino detect 0V and anything upto 10V.Because I've read somewhere that the input range is 7-12V
prak
Prak,
The Arduino's analog input pins can only read 0-5v. The 7-12 volts you are referring to is the supply power if you are using non-USB power. The Arduino has a voltage regulator that will take the 7-12 volts and regulate it down to a smooth 5v for the arduino to use. You can measure anywhere from 0-5v regardless of the power source as long as its at least 5v and 7v would be better because of the regulator.
Let us know if you have any other questions about this.
-Sam
LIFA Developer
HI
I just stmbled on LIFA today, and think this is really cool.
I'm not a Arduino user, but I develop on a lot of other micro platforms.
So my obvious question is: Is there a spec/white-paper that defines the packet protocol that LIFA uses with the Arduino, so I can adopt it with another processor/application to be compatible with the LV frontend and VIs?
I know I could beat through the code and figure it out for myself, but I figured there must be one somewhere.
The wheels are already turning
Phil.
Phil,
I have a nasty looking spread sheet that describes all of the commands but I doubt anyone else could make much sense of it. I can clean it up and post it here for reference. In a nutshell each packet has a header (currently its always just 0xFF but this can be taken advantage of later [its currently used mainly for wireless syncronization]) then a command byte, 12 argument bytes and a checksum (sum of all bytes with overflow discarded).
-Sam
LIFA Developer
I think having it posted here would be a great idea.
The document should also include expected response formats.
Showing an example command and response packet (bytes) would be fantatstic.
Yes! Please share whatever you can on the message format.
I just recently started playing with Netduino in my (limited) spare time. The I/O of the Netduino is the same as the Arduino, so it shouldn't be too hard to write a Netduino library and then use LabVIEW to interact with that as well.
I just downloaded the beta 4.2 .net micro framework and netduino SDK. I'm already using it to log to my Ethernet Sheild SD, and hope to get to a point where I can use UDP to broadcast syslogd messages that can be scooped up by the LabVIEW Syslog Protocol Reference Library.
With the newer Netduio+, the micro-sd flash and Ethernet are built in!
Do you have the I2C bus and SPI bus speeds posted anywhere?
I am working with LIFA on a 2560 and I have been able to successfully program all the digital pins as Input or output but the Analog ones I can only configure then as inputs, for some reason they do not work as output (PinMode (Output)) and PinType (Analog)). I have realized as well that for most of the examples VIs the number of analog pins is limitted from 0 to 7, when there are 16 Analog pins available on the 2560. I would appreciate any help on this. Thanks
It would be really Great if you could add support for Intterrupts .
Hi, i have one problem. I have LV 2011, i follow all the instructions to connect the arduino to LV but when i want to load the LV interface to arduino, always give me errors. And the gui tell me that i should search for an pbe, document something like that but i ujust see other formats. I try all of them but the errors are with them all.
The reason the analog pins on the 2560 can't be configured as outputs is because they are only input pins. Per the Atmel website, the ATMega2650 has 16 Analog-to-Digital Converter (ADC) input pins and no Digital-to-Analog Converter (DAC) output pins.
‎12-16-2013 03:14 AM
hello everone.
I m doing a dissertation work. For that i am using arduino uno. For the 2 way transfer of data between Arduino uno and Labview i have installed the NI VISA Drivers, VIPM and LIFA Toolkit. But now not getting the following .pde file which going to be installed in arduino.
I have also uninstall and reinstalled it. But not getting the .pde file.
Please hepl me out because it stop my work. Thanks in advances.
Here i m also attaching the scanp shot what i m getting.
What version of Labview are you using? If you are using a newer version of Labview you will need to modify the path to LIFA_Base. Substitute Labview20XX for Labview2010 in the path to LIFA_Base. Where XX is 11 for the 2011 version of Labview, 12 for the 2012 version of Labview or 13 for the 2013 version of Labview.
thank you hrh1818 for rpl,
I am using LabView 2010. And where should i do the changes as per your rpl. can u pl Tell me in detail?
Lets try a different approach to make sure LIFA_Base is installed on your computer. Use Windows Search capability to search your C:\ drive for the LIFA_Base file. If Windows can find the LIFA_Base file use the path shown to have the Arduino's IDE Open the file, compile the file and upload the sketch to your Arduino Uno.
If Windows can not find the LIFA_Base file most likely the VIPM installation of the LIFA toolkit was faulty. You can double check this by searching for "Arduino" examples in your installed copy of Labview.
I doubt if this is the problem but after 2010 Arduio changed the extension used by Arduino Source files. The extension changed from .pde to .ino. So don't be surprised ed if the LIFA_Base file shows up with a .ino extension.
hrh1818
hai there,
i would like to ask, how to install example into labview. please advice,
if could please have some video about it
i have done with all the procedures from install the labview,install the NI-VISA drivers, Install JKI VI Package Manager, install the LabVIEW Interface for Arduino , Connect your Arduino to your PC , Load the LabVIEW Interface for Arduino Firmware onto your Arduino but when i upload my work at the arduino IDE, it appear error for undefined reference. please help me ....by the way i'm using the labview 2013
Hi...
I want to connect Arduino to LabVIEW with input analog output serial but Arduino not connected to LabVIEW on my computer and I was Instaled LIFA on my computer, what problems? help me
and where I find status on LabVIEW
Thank you.
I do have very little knowledge on labview and i want know about
i know i am asking a very stupid question .do i have to write code in ardunio while i am using labview the graphical programing soft ?
and as a beginner what book should i follow to make robot ,i have already made obstracle avoding robot with ardunio .Now i want make a robot which can be control by xbee or wifi
plz help
I moved your question to Discussions. When looking for help please post your message in the Discussions category.
hrh1818
hi all. Could we send text instruction on arduino via the analog pin as with the FPGA?THANKS
Hi all. I used Labview Studnet Edition 2013, but I cannot install LIFA.
The error showed that VIPM cannot connect to Labview.
How can I solve it out?
i am using Arduino mini w/atmega 328 board and it is showing error 5003....... plz help me...... whether it is supported or not
Hi
These FAQs answered several questions in my mind!
Ali Raza
anishusna25 28 mars 2014 23:12
I have the same error !!!
Please Help.
I found LabVIEW education 2012 works with my Arduino Uno ONLY I use version 1.05 of the Arduino software. Now I am trying to get the rest of my student computers up and running. I can't find LIFA anymore. It has been replaced by LINX. Unfortunately, LINX is not supported in LabVIEW 2012. So.... Can you please post LIFA downloads again.
Mi FUE solucion ejecutar el firmware con labview cerrado..de modo que abri aplicacion arduino. conectoplaca reconos que esta vinculada con el pc, aprobro el lifa base para ejecutarlo en aplicacion arduino y la placa me da como respuesta tx y rx prendidos por un momento. hay ya tengo comunicacion...despues abro labview y a disfrutar!
saludos!
Once I update Arduino firmware using LabVIEW/LINX how do I go back to default firmware of Arduino?
Thanks.
hello all
I am new in arduino labview programming..
for my own interest,I have designed a small system in which I am reading data from senser and want to display on LCD
Getting problem when sending data to LCD.
Hello all, Is it possible to use this toolkit with ESP32?
Does someone already tested?
Thanks in advance.
