LabVIEW Interface for Arduino Discussions
LVIFA_Base... errors during compilation
I am trying to use the LVIFA_base example, but during the compilation I get the following errors:
LVIFA_Base.cpp.o: In function `loop':
LVIFA_Base.cpp:62: undefined reference to `checkForCommand()'
LVIFA_Base.cpp:68: undefined reference to `sampleContinously()'
LVIFA_Base.cpp.o: In function `setup':
LVIFA_Base.cpp:42: undefined reference to `syncLV()'
all the needed files are as downloaded from NI site.
May be I have to setup sorting before the compilation...
Some suggestions ?
(9,807 Views)
It looks like it is unable to find the Arduino API libraries.  Can you compile an example that comes with the Arduino IDE?
-Sam K
(5,327 Views)
Do you have the LabVIEW interface.pde and LabVIEW Interface.h files? It looks like those are out of context for the IDE -maybe you just have LVIFA_Base open.
Kevin Fort
Principal Software Engineer
NI
(5,327 Views)
I have the same problem.  There are no other copies of the Arduino compiler open if that's what you mean.  LVIFA_Base.ico is of course open in the Arduino compiler.  The undefined references are to functions in the LabVIEWInterface.h file in the last tab.  I can't imagine how it can't see that file if it's open in the same compiler instance.
(5,327 Views)
Hi giubio, did you solve the problem and how? I have same problem now. Any suggestions? Thanks.
(5,327 Views)
try opening the Labviewinterface.ino also in the same sketch in a new tab. This solves the compilation issues.
all the best!
(5,327 Views)
I also had a compile problem. I just had to upgrade my arduino software to 1.0.5
(5,327 Views)
