LabVIEW Interface for Arduino Discussions
Arduino uno stepper motor control
Hi everyone,
I am a new user of arduino. I am now using labview to control the stepper motor via arduino uno, with arduino labview interface.
I read the example of stepper motor.
My goal is to make the motor rotate back and forth several times automatically. ( say, 100 steps clockwise followed by 100 steps counterclockwise then 100 steps clockwise). I am new to Labview and arduino, could you give me some hint or show me some example VI?
Thanks.
(6,158 Views)
There is a stepper motor example in example finder (Help>>Find Examples then search for Arduino).  The same example should also be on the LabVIEW Interface for Arduino Palette.
-Sam K
LIFA Developer
(4,834 Views)
Dear Sammy, in the help example, there is an example for stepper
But the problem is with the LIFA.
how can i edit it sir
I am having problem with this issue.
is there a solution
(4,834 Views)
Dear jiangyihanin1990
for your interface right, how did u do the LIFA
(4,834 Views)
Hi
I did it last year as a project and this is a simple way of doing it.
1.Download the VI Package Manager (Install LabView Interface for Arduino )
2.LabVIEW Tools Network
3.LVIFA_Base_project
4.LabView  (Help>>Find Examples then search for Arduino then choose Stepper motor)
On the example Labview stepper motor you will find out that pin 2 is for direction and pin 3 for step , use the sparkfun easy driver for the bipolar stepper motor.
(4,834 Views)
Hello sir
yeah i already download the labview interfae everything . i also have the example for the stepper motor
i will attach the photo of my circuit.
i did the coding in arduino apart.
but not in the LIFA
how did u do urs.. which LIFA did u upload.
actually i want to like just give a number of steps and the motor will rotate according to that position10149976_10202646553678541_1050538204_n.jpg
this is the circuit of the driver with the motor
(4,834 Views)
