LabVIEW Interface for Arduino Discussions
LSM6DSO accelerometer with gyroscope
I would need to read data from both accelerometer and gyroscope using LSM6DS0 IC.
I am going to connect my IC board to an Arduino Uno using I2C.
I would need some recomendation on LIFA file.
Do I need to create a library (header file) and used that library in my sketch file(cpp)?
if I am going to use LIFA, do I just add more code to the LIFA_BASE.
Please help me.
(7,454 Views)
If the sensor uses I2C, you don't need to change any code in LIFA_Base.ino or any other Arduino sketch code.  Simply use the LIFA I2C functions like I've done with the MPU-6050.
(5,405 Views)
if I am only using these three functions, I would not need to add any extra library.
do I have only upload the Lifa_base?
(5,405 Views)
Yes, I2C is supported by LIFA.
(5,405 Views)
Thanks nathan.
(5,405 Views)
By saying that, I just need to add some comment in setup & void loop of the LIFA_BASE.ino file.
I mean some initialization and some comments for these raed write registers.
(5,405 Views)
You shouldn't need to add or change anything in the LIFA firmware if you are using I2C devices via LIFA.
(5,405 Views)
