‎04-07-2017 10:15 AM
Hello everyone!
I need to read a couple of RFID tags and then perform actions with a robotic arm.
How can use the library MFRC522.h into the Labview?
May I add the C++ code into the LIFA_Base?
Will I need to create a new vi?
Thanks.
‎04-09-2017 01:52 AM
Hello, I have the same problem. I am searching for some example of LabView interface of Arduino UNO with RFID-RC522.
Could somebody more experienced help? 🙂
‎04-14-2017 05:01 PM
You can use existing Arduino libraries with LINX (which replaced LIFA several years ago) using a LINX Custom Command. If you have issues implementing this, you should post on the LINX forums.
‎04-26-2017 10:46 AM
Thank You Nathan_B for an advice. With LINX I finally managed to deal with RFID reader.
‎05-05-2017 03:25 PM
Hello Jakubbe I'm kind of stucked in the same problem I want to interface my labviw with MFRC522 can you help to find out ho you did it ?
‎05-07-2017 02:08 PM
Hi Anouar47,
as Nathan_B adviced the easiest way is to use a LINX and Custom Command. This way let You to use existing libraries for RC522 to read mifare card and pass data to LV.
Here is the best tutorial according to the topic which I found: https://www.youtube.com/watch?v=DGTbRQR-x_4 Based on another sensor, but the idea is the same.
If You still will be stucked in this place let me know 🙂
Regards.
‎05-07-2017 03:43 PM
Thank you so much Jakkube I will let you know
cheers buddy
‎04-21-2019 04:03 AM
can you show me how to build the rc522 in labview linx?
‎12-12-2019 04:37 AM
Can u show me ur RFID redear? Thanks.
‎03-12-2020 09:34 AM
Hello jakubbe. Would you please share the custom Arduino file that you used.
