LabVIEW Interface for Arduino Discussions
Help required to setup Arduino interface with Labview
I recently installed Labview 2011 evaluation version to my laptop. I also downloaded arduino environment and was able to check 'Blink' example with Arduino Uno. However, I have problems interfacing Arduino with Labview. I uploaded the LVIFA_Base.pde to the Arduino Uno and tried executing the Simple_LED (https://decibel.ni.com/content/docs/DOC-20044) example. But I couldn't communicate properly with LabVIEW front panel and Arduino. It gives me error 5002 and says could find Arduino Uno. Kindly provide suggestions.
(9,974 Views)
You probably need to specify the COM port for your arduino manually on the Init block. It could also be a mismatch of the baud rate between the firmware on the arduino and the LabVIEW code.
Kevin Fort
Principal Software Engineer
NI
(4,941 Views)
Hi Kevin, Thanks for the reply.
By the way, how could I specify the baudrate in the firmware?
Below is the firmware that I am using.
**  LVFA_Firmware - Provides Basic Arduino Sketch For Interfacing With LabVIEW.
**  Written By:    Sam Kristoff - National Instruments
**  Written On:    November 2010
**  Last Updated:  Dec 2011 - Kevin Fort - National Instruments
**  This File May Be Modified And Re-Distributed Freely. Original File Content
**  Written By Sam Kristoff And Available At www.ni.com/arduino.
** Includes.
// Standard includes.  These should always be included.
#include <Wire.h>
#include <SPI.h>
#include <Servo.h>
#include "LabVIEWInterface.h"
**  setup()
**  Initialize the Arduino and setup serial communication.
**  Input:  None
**  Output: None
void setup()
  // Initialize Serial Port With The Default Baud Rate
  syncLV();
  // Place your custom setup code here
**  loop()
**  The main loop.  This loop runs continuously on the Arduino.  It
**  receives and processes serial commands from LabVIEW.
**  Input:  None
**  Output: None
void loop()
  // Check for commands from LabVIEW and process them.
  checkForCommand();
  // Place your custom loop code here (this may slow down communication with LabVIEW)
  if(acqMode==1)
    sampleContinously();
(4,941 Views)
The baud rate is set in LIFA header file. There should be a line that sets the default baud rate. It will set different rates based on whether you have an Uno or a Mega
Kevin Fort
NI
(4,941 Views)
That helps a lot!
Thanks for your kind reply.
(4,941 Views)
Chocka, can u please post the complete codes of yours here?
(4,941 Views)
