LabVIEW Interface for Arduino Discussions
Help in Labview
Hello. I need to control light dimmer using Labview. I use Arduino for the coding as well. But then to interface between two software, what should I do?
(3,959 Views)
Post a copy of your sketch.  I will look at it to see if I have any recommendation.
hrh1818
(3,634 Views)
the links below are the circuits and coding for arduino. I need a code for labview. however, interrupt is not possible in using LIFA. But i think VISA serial can do it. I am lack of experience in labview. So could you please help me on this?
https://drive.google.com/file/d/0B-TRZEZS2sxbNjFQdVdZQ1REdEk/edit?usp=sharing
https://drive.google.com/file/d/0B-TRZEZS2sxbYnRBQTV5eDlCYkk/edit?usp=sharing
https://drive.google.com/file/d/0B-TRZEZS2sxba2FTZ2VEMDJfLTg/edit?usp=sharing
(3,634 Views)
