LabVIEW Interface for Arduino Discussions
Fails to upload LINX
Hi!!
we are using labview 2014 and tried to connect Arduino UNO board using LIFA_Base.ino file but it fails to upload.
kindly provide suitable solution.
thanks
(3,928 Views)
LIFA was designed using an older version of the Arduino IDE.  LiFA will not compile with newer versions of the Arduuino IDE.  Try using using version 1.05 or older to compile the LIFA_Base.
hrbh212
(3,534 Views)
You should use LINX since LIFA is no longer officially supported.
http://www.labviewmakerhub.com/linx
For support for LINX, please post in the LINX forums.
(3,534 Views)
