Some courses and learning paths on NI Learning Center may not appear on learner dashboards. Our team is actively investigating.
If you encounter access issues, please contact services@ni.com and include the learner’s name, email, service ID or EA number, and the list of required courses.
LabVIEW Interface for Arduino Discussions
Fails to upload LINX
Hi!!
we are using labview 2014 and tried to connect Arduino UNO board using LIFA_Base.ino file but it fails to upload.
kindly provide suitable solution.
thanks
(3,736 Views)
LIFA was designed using an older version of the Arduino IDE.  LiFA will not compile with newer versions of the Arduuino IDE.  Try using using version 1.05 or older to compile the LIFA_Base.
hrbh212
(3,342 Views)
You should use LINX since LIFA is no longer officially supported.
http://www.labviewmakerhub.com/linx
For support for LINX, please post in the LINX forums.
(3,342 Views)
