LabVIEW Interface for Arduino Discussions
Beginning
Hello Everyone
I new in LabVIEW Interface for Arduino. What do you suggest me ?
I am triying to do wall follower Arduino project.
Thank you for your attention.
Message 1 of 9
(6,171 Views)
My suggestion is don't use LIFA.  The easiest way to i,implement a wall follower is to use Arduino code fund by searching with Google.
hrh212
Message 2 of 9
(5,318 Views)
Actually also ı want to start using LIFA. But ı do not know how can ı start ?
Message 3 of 9
(5,318 Views)
A good way to start is to run the Arduuino Analog Read Pin.vi that comes with Labview.  Then next try out the LIFA digital input and output functions.
hrh212
Message 4 of 9
(5,318 Views)
What do u think Linx ?
Message 5 of 9
(5,318 Views)
Yes LINX is preferable because LIFA is no longer actively supported by National Instruments,
hrh212
Message 6 of 9
(5,318 Views)
Than you
What do you suggest me for beginning Linx ?
Thank you for your attention and time.
Message 7 of 9
(5,318 Views)
Look at the examples that come with LINX.  When you run the firmware wizard, you will get an option to run an example called "Blink", you should do that and you can look at the code.  There are other examples in the example finder as well.
If you have further questions regarding LINX, you should post on the LabVIEW MakerHub forums.
Message 8 of 9
(5,318 Views)
Go to this getting started page :
<https://www.labviewmakerhub.com/doku.php?id=learn:tutorials:libraries:linx:getting_started>
There is also a link to LINX Tutorials and a LINX FAQ on the above web page.
hrh212
Message 9 of 9
(5,318 Views)
