LabVIEW Interface for Arduino Discussions
!! Arduino Uno + HC-SR04 Ultrasonic sensor + labview Help!!
yeahh, now i it works after i change the baudrate to 112500......
thankss Mr.Nathan
Message 61 of 72
(6,767 Views)
sir i did all the steps but sill i am unable to interface my ultrasonic sensor with arduino through LabVIEW please help me.
distance indicator shows a fix value 48.
i am attaching my files. please help me.
Message 62 of 72
(6,568 Views)
please send me your vi and sub vi's
Message 63 of 72
(6,566 Views)
at salimnitk@gmail.com
Message 64 of 72
(6,566 Views)
using LINX this is my code and indicator shows 0 please help me
Message 65 of 72
(6,565 Views)
Hello, Mr. egaruz89
I don't know, you will check this message or not. You solved this (Arduino Uno + HC-SR04 Ultrasonic sensor + LabView Help!!) about 4 yrs ago. Now I am facing the same problem and followed your instruction (HC-SR4ultrasonicsensor.pdf). but it does not work. It always shows a fix value 48.I have attached the VIs here. I am using Arduino Mega 2560 and Arduino 1.8.3. LIFA_base is ok.
Would you check and figure out the problem, please?
Message 66 of 72
(6,534 Views)
Hello, would you be kind enough to re upload the function block again?
Thanks.
- Alan
Message 67 of 72
(6,284 Views)
Help please solve the problem with HC-SR04 sensor, when connecting the sensor to Arduino, does not determine the distance, after passing the terminal Read.vi the value is 0.00E + 0 in Highlight execution mode (yellow light). For example, blink checked, everything works. What could be the problem? Connected components are all right.
Message 68 of 72
(6,043 Views)
And your links don't work(
Message 69 of 72
(6,043 Views)
how the code lifa in arduino IDE
Message 70 of 72
(4,544 Views)
