‎01-13-2016 09:28 AM
Look at this, in Arduino IDE I am using Arduino Duemilanove or Diecimila, ATmega328 because I cannot upload a sketch when I choose the Arduino UNO. So in LabView, when I am uploading the LINX firmware in the "Device Type", I'd select Arduino Uno (I tried Leonardo as well) for a silly reason that the board that I am using right now looks like the UNO (I know that is silly).
By the way, the board that I am using is a local brand here in my country.
When I tried the Blink Example I keep on getting the same errors over and over again.
‎01-13-2016 08:31 PM
LINX does not provide native support for either the Duemilanove or Diecimila, probably because the Arduino community has retired those boards. I'm not familar with either of those boards so I'm not sure what would need to be changed to make it work.
I'd recommend that you search on the LINX forums. If you don't find any topics regarding the Arduino Duemilanove or Diecimila, you can post a topic and see if anyone has had any experience with them using LINX.
‎01-13-2016 08:47 PM
Thank you Nathan for helping me out and for the patience. I'll get back on this one. I've already posted a thread in LINX forum. ![]()
‎01-14-2016 01:14 AM
Hey Nathan, I am now using an Arduino UNO. Here's what I did. Uploaded my arduino code. Then go to LabView, uploaded the LINX Firmware. I run the VI I created but I get an Error 5001. Here's a preview:
I tried the Blink (Simple) example and it is working. No errors whatsoever.
‎01-14-2016 05:17 AM
I am now getting this error.
‎01-14-2016 07:02 AM
Here's what I did now:
I move the ADXL345 OPEN block inside the While Loop. Removed the ADXL345 CLOSE block. I am no longer receiving the error. However, I am not getting any real-time reading from my sensor.
When I click the "Run" button, it will run for some seconds then will stop automatically. The x,y,z data then will have a new set of data.
Here's the snippet of my VI.
I think what causing the Error 5004 is the ADXL345 Close Block. So I removed it.
But what I really need is the real-time reading of the data because I need to plot them.
‎01-14-2016 10:13 AM
UPDATE:
First of all, sorry for my constant post on this thread.
I think I figured out the way to plot the data real-time. However, when I click run, it will not start reading/plotting the data until after 10 secs. Is that normal?
Also, if you could help me out on how to properly calibrate the values that I am getting because the values are very small and it reads at a high rate. (When I use the serial monitor in the Arduino IDE, the x,y,z values are from - value to 500+ value.)
Here's the snippet of the VI as well as when the program is running.
Right now, I am figuring out how to reset the data when I click the run button again.
‎01-14-2016 11:40 AM
When you first run the VI it needs to connect to the Arduino which is not
instantaneous.
The values you get are in units of gravity (g).
‎01-14-2016 07:24 PM
Ah so it's normal.
So how can I make the reading looks something like the image below?
or the reading that I am getting right now is more accurate and reliable? Additional question, if I simply change the constant 2 value in my VI to 16. Does that mean I am now running at 16g range?
‎01-14-2016 08:10 PM
JersonJose wrote:
Ah so it's normal.
The data is the same, it's just been properly converted into units of gravity.
No. If the sensor supports it, you would have to set the range parameter on the ADXL345. In this case, it looks like you'd need to create a new VI to do this since it does not appear to be a function that's already been created.
Since we are no longer talking about LIFA (this forum), you should take your discussion to the LINX forums for support with LINX (there will be more people able to help you).
