User | Kudos |
2 | |
2 | |
2 | |
2 | |
1 |
It would be nice if I could simultaneously edit all cases of a case structure. There are times when I need to edit all cases of a case structure in the same way, e.g. adding a constant to an output or pulling shift register wires from one side to the other. Right now I need to step through each of the cases and perform this task. It would be great if I could select a "punch through" option on the case structure context menu at which point my block diagram changes are applied to all cases in the structure.
