If you have, for example, an 8-elements array, you can easily increase its dimension to 16 elements by left clicking its bottom line, and dragging it downwards. Then, simply enter a value on the 16th position (and enter all other new values according to your needs).
But if you have to perform the opposite operation, you must right click all the elements to delete one-by-one, and select "data operations -> delete element".
That can be really annoying: I'd like to see implemented the possibility to select multiple elements, and to delete them at once (or at least, to see an option like as "data operations -> delete all elements after/before").
