There is no way to add programmatically a 2nd y axis. Need it to display same data with different units on left and right y axis but currently there is no way to add a 2nd y or x axis programmatically.
I know this isn't exactly what you are hoping for... but I have found a work-around for your issue. Create all the axis you think you might need, then hide them. Then you can make them visible/hide them as needed via property nodes. I am doing this currently in my application...I have 8 Y axis (4 on each side) and 4 X axis (2 on top and bottom) and I just modify their visibility as the program is running.
That being said, I agree with you....would be nice to be able to actually create them at runtime.
