User | Kudos |
3 | |
3 | |
2 | |
2 | |
2 |
When a complex application uses deeply nested clusters to organize their application data, it can be difficult for others trying to extend/maintain that code if they are not intimitely familiar with the names and the datatypes of the elements within the data structure. Is that element a integer, enum, string, path, array, cluster, object?
The context help provided when hovering over wires and the color and texture of the wire on the diagram is very useful, but neither of these are available when you are attempting to select the correct element from the bundle/unbundle nodes.
I propose that the same datatype glyphs shown in the context help when hovering over wires should also be visible when attempting to select the correct element in the bundle/unbundle nodes.
