I started this discussion
http://forums.ni.com/t5/LabVIEW/how-to-prevent-an-enum-control-from-wraping-around/td-p/3089021
and someone suggested to put it here in the idea exchange.
I think it would be great to have a check box in the properties window of an enum control where I can select if the enum control should or not wrap around when clicking the up or down arrow and the top most or bttom most value is reached ( and taking into acount that there may be some values disabled)
Another idea concerning enums is to enable editing the value of each entry. As much as I found out values always start at 0 and increment by one with each entry.
Hope these ideas help improve LabView
Martin
