User | Kudos |
6 | |
5 | |
2 | |
2 | |
2 |
We can get the top level VI using property nodes / call chain, and we can also determine the running state of any specific VI (given a path).
It would be really useful to know which VI was running as any point in time (without resorting to execution highlighting) - not really applicable to time critical applications of course.
Uses for this include:
1) the abilty to change a VI execution state from Modal to normal with custom created dropins - if required.
2) Automation - it would be really useful to retrofit projects with a tool/dropin for soak testing / debug which detected certain windows - normally these would be modal dialogs and entered data in them to allow the program to continue (I know these features can be built in at the start of a project, but dropping in later would be very powerful for pre-existing ones and allow the use of the NI dialogs.
3) simple debug - code is stuck, exection highlighting is not showing where. This would give the answer.
James
