Andromeda
When replacing an arithmetic node with a compound arithmetic node, select the correct operation mode
One of the common uses for the compound arithmetic node occurs when you are refactoring a VI, and realize that you need to, say, add or multiply three numbers instead of just two. So, you replace, say, a multiply node with a compound arithmetic node. The wires all stay corrected which is nice, but the default mode is "add", even though you just replaced a multiply node.
With just a teensy bit of added intelligence in the diagram editor, the mode could be set in the compound arithmetic node, based on what it was you just replaced.
J. Heerema, PhD - LabVIEW specialist
3 Comments
AristosQueue (NI)
NI Employee (retired)
Andromeda
Thanks for the update - I'd missed that thread!
Laura F.
