OwlMan
Waveform Graphs Axis drop down menu
Status: Declined
I have an application where it would be nice to change the data displayed by clicking on the y-axis or x-axis labels themselves as oppose to a separate enum type, button or switch residing outside the graph.
For example:
If I want to look at Voltage or Current vs frequency or time currently you could use enum types outside the graph. It would be handy to  select the y-axis label in real-time (during or prior to runtime) and change the data displayed. If you click on the y-axis label you can have enum type drop-down that is read horizontally and when you select the unit you want the label would be displayed vertically or make it custom depending on what the user prefers.
The same thing can be done for the x-axis. So in one graph I can click and select the x-axis label and select Time and selelct Current for the y-axis and depending how I set my program see the data displayed as it should be in real time in one clean graph. No side buttons or switches.
Would anyone else like to see this feature? Thanks.
1 Comment
Darren
Proven Zealot
Status changed to: Declined
