Whenever we add a new item in tree programatically using "edit tree item" node,
We are not sure what tag would be set to Child Tag. Because if that tag already exists LabVIEW will appends a number to make it unique.
From help of "Edit Tree Items:Add Item Method"
| The default is the string you wire to Left Cell String. If an existing tag already uses that string, LabVIEW appends a number to the string to create a unique tag for the new item. |
It would be great if we can get the value of "Child Tag" as output as well, which is set by LabVIEW.
The requested functionality is already present as described in the reply by thols. I have filed CAR 713843 against the documentation for the Add Item method to clarify that it outputs the unique tag for the new item.
