manu.NET
Update while typing for comboboxes ....
Status: New
When using comboboxes with "allowUndefinedString Flag" set to true, it should be nice to be abble
to catch an event during typing ... and before the control validation.
So it could be possible to analyse the typed string ... during writing ... in order to made string check ... enabling or disabling buttons ... etc ...
Manu.
Manu.net
4 Comments
shb
In string controls you can set Update Value while Typing in the context menu. A combobox only has this as a property in the property node. It should be added to the context menu.
But setting this property has some drawbacks:
 * You do not know when the value is final (the user hited enter or clicked into another control)
 * Editing the value can no longer be canceled by escape
Using the the key down event combined with the combo box property Text.Text sounds better:
shb
see also in Darren's Weekly News
manu.NET
Thank you shb,
Your solution "key down + combobox.text" works fine ! Smiley Very Happy
Manu.
Manu.net
sushu
greate.
sushu;
Certified LabVIEW Developer (CLD);
