Changing the symbols on the tree control isn't easy at all, even the first 40 available ones. It would seem logical that on a double click event, the tree control would know the active item. Unfortunately it doesn't and should be changed. Here's some simple code that illustrates the extra code needed. This necessary code is not anywhere on the NI website or in the examples. Only a lavag.org thread provided a subtle hint...thank you crelf!
Any idea that has received less than 4 kudos within 4 years after posting will be automatically declined.
