altenbach
The minimum size of classic framless colorboxes should be two, not five
Status: Already Implemented
Already possible in LabVIEW today. See discussion thread for more details.
I sometimes use arrays of classic frameless colorboxes to quickly display a color table.
Unfortunately, the minimum size of these elements is 5 pixels :(, making a 256 element color ramp 1280+pixels wide, showing redundant information in 5 adacent pixel columns each.  If we display the color ramp vertically, it would not even fully fit on a common 1080p display!
This makes it too wide to correctly display them in the forum and forces a size reduction that makes all other text and diagram code illegible.
(Yes, we can right-click...open image in new tab, and click the image to display it 1:1 (in chrome), but that's more work and not everybody knows that)
It would be perfectly OK if we could make these elements only 2 pixels wide (or high), making the array display a much more reasonable 512 pixels and keeping the front panel to a more reasonable size.
Idea summary:
The minimum size of the classic colorbox (frameless) should be 2x2 pixels (or even 1x1?) Currently it is 5x5, i.e. too big.
16 Comments
AristosQueue (NI)
NI Employee (retired)
Jannis:
The code you've written is why LV probably hasn't bothered to create such a control before now. It's a fine way to do it most of the time. BUT the code you've written is slow by comparison to the rendering speed of the 2D array. There's a lot more memory allocation, which can matter significantly for a large 2D image. What it does is copy the data into the pixmap cluster, then create a string that contains that cluster, then parse that string to render the image, then render the image.
Also, you're missing the first transform from 2D array to 1D array.
Jannis
Yepp, I was wondering how much overhead there actually is in using the PictureControl! Now I might consider using the Matt_McLaughlin-Array instead for image displaying. Missing the extra feature of being able to draw on top of it of course. Unless I'm also faster in creating the overlays myself? - The Matt_McLaughlin-Array is a 2D array also. So there is no difference.
altenbach
Knight of NI
Thanks for the small colorbox!
> building the Boolean is not so easy -- there's chrome on the Bools that would need to be modified. More than just a few minutes of work that the color box took.
I just noticed that the size restriction is less in the control editor. I can actually create a 1x1 or 2x2 "classic flat square button" or "classic colorbox"!!!
If I try to resize on the front panel using the "set width and height" tool, the size coerces up to 5 pixels. However if I use the same tool in the control editor, I can get down to 1x1!
Here's a 1x1 classic flat square button!
Still, the idea would be to lift the limitations also while in the VI editor, so it should probably stay. However, there's a good workaround. 😄
AristosQueue (NI)
Neat. At this point, I'll ask Darren to close this idea as Already In LabVIEW.
altenbach
Knight of NI
Thanks! It was somewhat surprising that the same "Resize Objects" tool has different restrictions depending on where it is called (VI editor or control editor). Who would have thought? 😮
Obviously it is trying to protect the user from making extreme choices, but maybe the restriction should be lifted also in the vi editor. Typically, the users knows best. 🙂
Darren
Proven Zealot
Status changed to: Already Implemented
