User | Kudos |
2 | |
2 | |
2 | |
2 | |
1 |
The Search Results window should contain a “Remove” button. When the button is pressed, the selected item(s) would be "removed and rewired" using the exact same implementation that operates behind the QuickDrop Ctrl + R shortcut. This functionality would be useful when refactoring codebases. Currently the quickest way to remove and rewire n instances of a subVI is to navigate to each instance (perhaps using Search Results Ctrl + G) and perform the QuickDrop Ctrl + R shortcut on each instance. The "Remove" button would enable n instances to be removed in a single bulk operation.
