| User | Kudos |
| 10 | |
| 6 | |
| 5 | |
| 3 | |
| 2 |
Hi All,
I felt that it would be good to have an option to switch to a previous case in a case structure with numerous cases when going through the cases for debugging or understanding a code. It often happens that I have to scroll through the list of cases to get to a case and then may be I'll have to check something in the top most case. Again if I have to check the previous case, I have to again scroll all the way down to the case, which becomes a little tedious. Instead, it would have been good if we had some kind of option to switch to the previous cases sequentially (in a right click menu of the case structure or some keyboard shortcut after selecting the case structure). Something similar to the "Previous Sequence" and "Next Sequence" options we have in TestStand.
I'm sorry if someone has already posted this in the idea exchange forum. I tried to search it but couldn't find any such posts.
regards,
Nitz
