Kelsey_Weaver@NI
Sine Wave.vi Function Generator Frequency input modification
Status: Declined
Any idea that has received less than 3 kudos within 3 years after posting will be automatically declined.
The Sine Wave.vi (base) function generator allows you to generate a sine wave in software. You can specify inputs like frequency, amplitude, phase, and number of samples to create. The frequency input is in units of "cycles/sample" instead of "Hz". Some people don't always recognize this and have trouble getting meaningful data from the VI. It would be more obvious if the input were labeled "Frequency (cycles/sample)" instead of simply "Frequency".
Kelsey W.
Applications Engineer
2 Comments
Manzolli
Even though the information is complete in the help, in the context help is not. Kudos!
André Manzolli
Mechanical Engineer
Certified LabVIEW Developer - CLD
LabVIEW Champion
Curitiba - PR - Brazil
Darren
Proven Zealot
Status changed to: Declined
