Functionality already available with the Ctrl-T shortcut in Quick Drop
If the Label Position is changed from default position there should be the option to retain the position, because finding the label in a very huge block diagram code is difficult as label is the only identification for the item
Senthil Prakash S Certified LabVIEW Associate Developer
Quick Drop already does this! Open QD with CRTL+SPACE and then use CRTL+T.
There are only two ways to tell somebody thanks: Kudos and Marked Solutions Unofficial Forum Rules and Guidelines "Not that we are sufficient in ourselves to claim anything as coming from us, but our sufficiency is from God" - 2 Corinthians 3:5
