When you choose Rearrange Cases it should auto-select the current case that you are editing when the window comes up.
This can save programmer time when editing case order.
Available in LabVIEW 2020 and later. When you select 'Rearrange Cases' on a multi-frame structure, the currently visible frame is selected in the Rearrange Cases dialog box.
