CL_eisenwr
Python Node: Support Dictionaries as Maps
Status: New
It would be helpful if the LabVIEW Python node natively supported Python dictionaries as LabVIEW Maps. This would make it simpler/easier to support a frequently use Python structure. You can work around but you have to do extra data preparation/formatting in both LabVIEW & Python. It would be nice if the node handled that converting to list of tuples and building the LabVIEW map or vice versa for us.
__________________________________
Bill Eisenhower
Certified LabVIEW & TestStand Developer
2 Comments
Bugpower
Absolutely. Just stumbled about the same problem... 😞
D*
Dict support would also support **kwargs!
Support for Python dictionaries would also enable support for the very commonly used Python functions that expect keyword arguments,  commonly seen like: **kwargs.
This Idea would remove this LabVIEW deficiency:
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z000000g0BmSAI&l=en-US
