User | Kudos |
13 | |
7 | |
3 | |
3 | |
3 |
If you develop an application using functionality from the OPC UA Toolkit on a machine with a developer license covering the OPC UA toolkit you cannot run the built application to test if it works without having to buy a deployment license for that machine.
Having a developer licens on a machine should allow us to run built applications as well the same machine to verify the functionality after build (alternatively the developer seat should always be accompanied by a deployment license).
