取消
顯示結果
搜尋替代
您的意思是:
sandyy
Node to update status to Front panel ( Without using Property node - Value )
狀態: Declined
Any idea that has received less than 2 kudos within 2 years after posting will be automatically declined.
9 回應
crossrulz
Knight of NI
Like a Local Variable or (even better) the terminal...
tst
Knight of NI Knight of NI
Knight of NI
Other than the local variable, LV 2013 also added another primitive which allows updating the value of a control using an index without going through the UI thread. In practice, this is relevant mainly if you want to do the update in a subVI or if you want the error IO.
___________________
Try to take over the world!
RavensFan
Knight of NI
Tst,
Which primitive is that?  I might have heard of it, but I can't think of what one you are talking about right now, so I'm not sure.
crossrulz
Knight of NI
Get Control Value By Index and Set Control Value By Index are the primitives Tst is referring to.  They are in the Application Control palette.
muks
Proven Zealot
搗亂者
One more reason for upgrading!!!
sandyy
All,
Oh is it from LV2013?
sandyy
can u pls add a snap shot of it? i didnt have 2013.
crossrulz
Knight of NI
Darren
Proven Zealot
狀態已變更為 Declined
