Mark_Yedinak
Native support for IPv6
Status: New
With the IPv4 address pool quickly getting used up I think we need to have native support for IPv6 connections in LabVIEW.
Mark Yedinak
Certified LabVIEW Architect
LabVIEW Champion
27 Comments
Mark_Yedinak
Trusted Enthusiast
I think the list looks pretty good. Would Web services need to be pulled up or is it basically just LabVIEW internals commuting with it? If external browsers or application will use web services it may need to be ahead of netwrok streams.
Mark Yedinak
LabVIEW Champion
JaredW
NI Employee (retired)
What about NI Hardware Support? Where on the priority list would everyone recommend network enabled devices (cRIO, etc) having an IPv6 address, and be discoverable in LabVIEW's project?
Siriusly
New PCs are starting to come from the factory with IPv6 as the default protocol.  I have learned that if my custom LabVIEW application uses TCP, IPv6 needs to be manully turned off in the network settings configuration window.  This causes issues with some of our customers PC's as they don't always have full administrative priveledges and/or we are not always dealing with the technially savy.  LabVIEW needs to address this issue as it not going away anytime soon.   I think starting with the basic TCP Functions would be a sufficient start.  Looking forward to the enhancements.
Mark_Yedinak
Trusted Enthusiast
I think both TCP and UDP should be addresses. I also wonder given the issue above if things liked network streams and shared variables need to be updated as well. I do think NI needs to get on board with this sooner rather than later given computers and devices are now coming with IPv6 enabled out of the box.
Mark Yedinak
LabVIEW Champion
MM1957
I also need this support for testing data link products. I need LabVIEW to support IPv6 and SNMP.
MVidal
Still NI does not find IPV6 relevant?
Mauricio Vidal
VIDAL & ASTUDILLO Ltda.
http://www.vidalastudillo.com
perj
We really need to start testing with IPv6. Will LabVIEW support this in version 2016? This is VERY important for many of our products!
Mirash
Problem:
Does LabVIEW and/or the Internet Toolkit for LabVIEW support Internet Protocol version 4 (IPv4) or Internet Protocol version 6 (IPv6)?
Solution:
LabVIEW only supports IPv4. National Instruments will continue to monitor the demand for IPv6 and may add support for this technology to future releases of our products.
IPv6 is short for Internet Protocol version 6 and is the next generation protocol designed by the Internet Engineering Task Force (IETF) to replace the current version which is IPv4.
For more information about these two versions of Internet Protocol and how their packets are structured, please see the related links section below.
Is NI still monitoring..?
Mirash
Coding is a combination of intelligent and creative work - someone
Tanja_Troescher
Hello together,
we also need IPv6 for TCP and UDP, to communicate with our automotive devices.
Kind regards
Tanja
crossrulz
Knight of NI
Tanja,
Then be sure to give the idea a kudo.  The kudo count has a lost more influence than a random comment.
