Subversion is one of the most popular SCC systems in use yet currently LabVIEW can only integrate with the help of rather flakey 3rd party plugins. It would be so much easier if LabVIEW included native SubVersion support, allowing full integration with the LabVIEW Project etc.
NI has no business flirting with open source anything, especially SCC. Leave that to the LAVA and OpenG and the like guru communities to play around with. NI trying to support any open source product could be a huge headache and they would be stuck with it for LIFE. This is Source Code Control for cryinoutloud! That said, having NI work with Perforce (which is the SCC NI uses) to give us Perforce tuned for NI products at a reasonable price could be sweet.
I think a better idea would be to have NI publish an API for integrating SCC systems into the project. Maybe releasing an unsupported example for SVN at NI Labs.
I agree that NI should not get into the SCC business. They did try
once going even one step further and creating an entire native SCC
solution, which was the start of the now existing SCC plugin interface.
While in theory a nice try, the practical use of that provider was
minimal and it was consequently scrapped in later releases.
I
once started with a direct DLL interface to the SubVersion client
libraries that would support virtually every SubVersion feature but
have after some serious time resolved to just calling the svn client
executable over the command line for the build-in version control needs
of some of my script based test applications.
The command
line is a bit tricky at times to use but it can do the job and
implementing an SCC provider on top of that for the LabVIEW SCC system would
be in fact not a very hard thing to do. I still would prefer the DLL
based interface to SubVersion for that. The Pros would be a much
tighter and more performant interface to SubVersions, the Cons are an
interface that could much easier break with new major versions of
SubVersions and a considerable effort to make the
LabVIEW<->SubVersion DLL interface. That interface uses Callbacks
and complicated datastructures that can not be interfaced directly from
within LabVIEW.
That all said, JKI has released a
LabVIEW SubVersion Tool that integrates in the Tool menu of LabVIEW and
might be almost as good as a full LabVIEW SCC integration.
And Lavezza, there is an API for the SCC providers, it just would need
to be better documented somehow. If you look in vi.lib/Source Control
you will see the API itself and the providers directory. You add an
additional Provider directory and for each VI in the sccapi directory
you need to implement an according VI in the Provider subdirectory.
True. When I said publish an API, I should have said document the API. Right now it isn't a trivial exercise. The funny thing is the P4CMD provider for the Perforce command line would be a great starting point for just about every other heavily used provider out there (CVS, SVN, git, etc.). If the P4CMD library was unlocked and the API was documented, I think we'd see an SVN client fairly quickly. Of course, if someone is resourceful enough it might be doable with what is available.
As a user of TortoiseSVN, I have to say that the implementation matters. TortoiseSVN pretty much sends batch commands to the command line behind the scenes, but it's interface is so transparent, that it's a real pleasure to use. In LabVIEW, I have to agree that the SCC API could use more documentation - and there are more API's in LabVIEW that could use that same treatment 😉
I agree that LabVIEW should work with SVN, BUT... Only after SVN better supports binary file formats (like VIs) and *locking* of files. We have 12 developers working at a time and using TortoiseSVN, pushOK and a few others did not work for us. Smaller projects with only a few VIs seemed to work okay, but when we got up into projects with thousands of VIs, SVN ceased being viable.
I think NI should support SCC systems that can handle the file formats and locking required for working in LabVIEW.
