Andi_S
Multi column 1D array (2D view for 1D arrays / lists)
Status: New
On a compact UI 1D arrays are very often uncomfortable.
On the one hand only a few elements can be shown, on the other hand there is often a lot of free space (usually on the side of the array).
My suggestion is to implement a 2D-View of a 1D-Array. Please see the pictures (1D-Array of a cluster control) for better understanding.
Left image: current view, 6 out of 10 elements are visible; right image: suggested 2D-View, all elements are visible
5 Comments
altenbach
Knight of NI
All you need is "reshape" it to 2D for display and maybe add a transpose operation.
The fancy way would be to make an Xcontrol.
fabric
@altenbach: Not so nice if the columns are of uneven lengths. That information is lost in 2D array...
@Andi_S: How would scrolling work?
Andi_S
@: for displaying it works as long as the number of elements is less than the visible number of cells. But as fabric wrote - the length information would be lost
@ fabric: scrolling should be identical to a 1D view just that the first field of colmn two moves to the last field of colmn 1 if you scroll down by one element.
_Y_
IMHO, in most of the cases, such UI could be confusing. In rare cases when it is needed, two UI units can be used (and the data array split at code side).
_____________________________________
www.azinterface.net - Interface-based multiple inheritance for LabVIEW OOP
Andi_S
how do you want to implement the scrolling through the data in this case?
