More function for tdms file.
The tdms files are a very good way to record data on disk, but some usefull function aren't present.
- you don't can delete a channel or a group or a value or a property
Exemple : You add the measurment in the group 'raw data', channel 'volt'.
In the group 'calculate data', you add the channel 'filtered volt'
You change the filetring parameters. You wan't to replace the channel 'filtered volt' with the new data, but you don't can easy replace the old data (channel 'filtered volt')
You must copy all data in a new file without the channel 'filtered volt' befor you can add the new calculation.
- you have only 2 hierarchy (group and channel). More should better ?
exemple : 'acquisition\device name\channel name\acquisition number'
Any idea that has received less than 7 kudos within 7 years after posting will be automatically declined.
