User | Kudos |
17 | |
5 | |
4 | |
4 | |
4 |
I use LabVIEW OOP quite frequently and I like to have a small alignment grid on my FP and BD. With LabVIEW, you can set these in the LabVIEW options for when new VIs are created, except for when you use LabVIEW Classes and VIs are generated by scripting.
It would be terrific if there were a way to extend this functionality to OOP Class generated VIs. Currently, I have to go to the properties tab of each VI and change this manually.
Current settings when VI generated by LV Scripting in class. Have to change manually.
Would like an option to be able to set the Class generated VIs similar to the LabVIEW environment settings in "Options"
This is my preference, but it may vary, it would be great to have this setting to automatically generate new VIs with desired settings, instead of doing it manually in classes.
