When running LVCompare from the command-line (i.e. from my Tortoise SVN shell) it will try to open the compare tool in the last context which was active. Unfortunately, the code required does not run in RT or FPGA contexts.
I would propose that LVCompare, when called int his way, should ALWAYS run in "My Computer" Context. Or even better, in a context all of its own (new Project).
여기에 의견을 추가하려면 등록된 사용자이어야 합니다. 이미 등록되어 있다면 로그인하시기 바랍니다. 아직 등록하지 않은 경우 등록 후 로그인하시기 바랍니다.
