When using the VI Analyzer on a VI, I will often go and fix any reported problem then and there in said VI. I then want to re-analyze the VI.
If I have launched VI Analyzer using then "Analyze VIs .... menu option then when I press the "Done" button on the results window I get the prompt below
If I say yes to return to the Analyzer I can then just run the same conditions agains.
However if I had launched the VI uisng a Quick Launch menu option pressing "Done" just closes down the VI analyzer and I have to navigatie back into the tools menu to the same quick launch tests that I ran before.
cheers
Dannyt
Any idea that has received less than 3 kudos within 3 years after posting will be automatically declined.
