User | Kudos |
8 | |
6 | |
4 | |
3 | |
2 |
Most of the time the only part of a VI that needs protection is the block diagram but there are a few instances of why including the front panel in the password-protection would be needed. Someone can see the front panel of a subVI during run-time even if it is under layers of password-protected subVIs.
For instance, an encryption application. Except for the Top Level VI, all other VI's are password-protected.
During run-time, the Key for the encryption algorithm, which should never be known, is shown on the front panel of the Key Generation VI as well as the Encryption SubVI.
Of course one work around for this would be to hide all items on the front panel of each subVI but this will slow down further development in the future. The ability to just type in a password would allow a developer to instantly return to work.
Also, an alternative solution would be to allow password-protected Source Distributions.
Can anyone else think of an application in which the front panel of a VI should be password-protected?
Other Notes:
It is important to mention that it is possible to do things like Remove the Front Panel or Remove the Block Diagram, but this does not allow the VI to be recompiled for different targets. This is why a password-protected Source Distribution would be ideal.
Any idea that has received less than 2 kudos within 2 years after posting will be automatically declined.
