When duplicating a case in a boolean case structure the result is a new case with a blank selector value. It would save me numerous clicks if the duplicated case became False or True depending on the current case. Otherwise I have to Swap or enter "false" followed by remove empty cases. If the other case already has code, then I would accept a new case, but not when it is empty.
