User | Kudos |
4 | |
3 | |
3 | |
2 | |
2 |
Similar idea as "Place Global Variables as the actual variable when dragged from the GV window, not as a constant of .... "
The ability to drag a control from the front panel to the block diagram and be able to choose between dropping a Local Variable, Reference, Property Node, Invoke Node (the same four choices when you right click on a control an select Create), or a constant.
Kind of like Window's right click options when dragging files.
Any idea that has received less than 2 kudos within 2 years after posting will be automatically declined.
