User | Kudos |
29 | |
10 | |
6 | |
5 | |
4 |
Using "Edit Palette Set" is cumbersome and painstaking.
Specific use case example: I create a class library that has an embedded menu file that I want to distribute as a compiled packed library (PPL) or even as a source code distribution for re use by other developers. To make the mnu available in the functions palette, you have to manually recreate the menu file to link to the versions of the functions inside the distributed functions, which is painstaking for a larger library.
It would really nice if we had the ability to generate or easily edit mnu files. In the example, a simple search and replace of the paths that the functions in the palette link to would work
