Any idea that has received less than 3 kudos within 3 years after posting will be automatically declined.
When I was debugging the RT code it was getting crashed whenever I open more than one VI which has large clusters. For displaying the values in the front panel certain amount of memory is required that was the problem. In some cases it is not required to see the values in the front panel and also it is not required to open the front panel either. So it would be good if we have an option for disabling the values updation to the front panel control and I believe it will increase the efficiency even when we open those vi's. This option can be made available in the control/indicator properties and also if we want to disable the whole control/indicators present in the vi the option can also be made available in the vi properties. By default the option will be enabled and the front panel updation can be disabled by removing the check mark in the check box.
I guess it is not proposed before.
I know this option but you need to write this to all the vi or make it as a module and keep it in every vi. What will happen if I keep this in my RT code? It will load the front panel for all the vi right? When I build an exe for the RT I usually enable the option remove the Front panel and Block diagram in that case what will be the state of the property node will that execute without any exception?.
I ran into the need for this today and stumbled upon this post. This is a great idea and would be very useful especially in the diagram.
My current VI connects about a dozen data sources and to debug I'm highlighting multiple controls (lists) and updating a lot of clusters.... it's great for testing and sure I can add diagram disables in the areas where data is written to indicators/local variables of indicators but it would be much easier and convenient to disable selective controls (or defer every x updates to help speed things up).
